robaloroger
Thread starter- Joined
- Feb 16, 2010
- 123
j70plssd top cylinder has spark and compression but no power. when motor is running and I pull each plug wire the motor runs really rough on the 2 lower but the upper does not make a difference. When I turn the fuel mixture screw on the carb it does not bog down like the other 2 carbs. I swapped coils but it did not follow. I swapped wires from power pack to coils and runs on only 1 cylinder and backfired. I am not sure If I should even do that. The bottom 2 cylinder plugs were dirty but top was spotless. could it be temp sensor wire? If temp sensor shuts down cylinder would I still have spark? Could it be something not allowing gas to reach cylinder? I could not see much when I removed the carb. No frayed or melted wires.. Dont know what else to look for.. Trying to get ready for mini season in FL..
