Mischief Managed
Thread starter- Joined
- Dec 6, 2005
- 1,928
Tested the charge coil, power coil (I do happen to have a Fluke 87 DVM that'll measure the peak voltage correctly) and they passed both voltage and impedance. Verified it's not the stop circuit. Inspected/cleaned the optical bits and they look fine. Battery connections are tight.
The only thing that seems off is the voltage at the yellow/red wire while cranking. I've read that it needs to be more than 11 volts and I only see 8.5 volts. Engine cranks nice and fast though. Planning to try a different battery tomorrow and if that does not change the voltage, will check the starter solenoid for excessive resistance with a bypass.
Assuming the battery and solenoid check does not help:
I don't really want to throw parts at it but it seems like it's either the optical pickup or the ignition module. Any ideas?
