2000 Larson 186Lxi
rvah
Anyone have any ideas on how the rear bench seat is removed?
Since Larson no longer exits, is there any support available for their boats?
JASinIL2006
No, I don't think so. Best bet is to post your question and some pics on the General forum and I bet you'll get some suggestions.
rvah
I'll try to get pictures next time I'm at the boat.
What I am trying to do is gain access to the fuel tank. On my boat there is an access panel, approximately 2' x 3'. The rear bench seat sets on top of the aft part of the panel. So far what I see is back of the seat (bulkhead in front of engine) there is a bracket at both sides. No problem there. Then there is a trim piece on the bottom forward side of the bulkhead that is screwed to the deck/ access panel. No problem there either. Next is inside of the seat storage area on the forward part there is 3 screws into the deck/panel. No problem there.
So does anyone know if there are other screws/fasteners that I should be aware of ? Does the whole seat/bulkhead come out in one piece ?
Trying to make sure I know the scope of the work before I get started.
Thanks for any help and info.
And thanks to whomever moved the OP to the correct location
Doug
