ThomW
Thread starter- Joined
- Aug 8, 2016
- 615
Hey guys. I am still in the process of rigging up a "new to me" Merc 200hp to my tri-toon. My newest problem is with the trim system. When I press the trim up and down buttons on the actual motor, the relays just click, but the trim motor doesn't move at all. When I press the up, one relay clicks, and when I press down, the other clicks. I have taken a battery and tested the actual trim motor and it works. I can hook up wires from a battery to the trim motor and get it to raise up and down. Both batteries in the boat are fully charged. I know relays are pretty cheap, but what are the chances of both going out at the same time? The guy I bought the motor from said trim was working when he tested it at the shop. What could be causing the switch to not activate the motor? The wring from the motor to the relays and switch all seem to be fine. Grounds appear to be clean and well connected. Any thought?
