Lastmatchstruck
Thread starter- Joined
- Jun 17, 2023
- 4
I just converted my original one piece batwing style exhaust manifold to the new two piece WET JOINT (OEM MerCruiser 4.3 V6 Exhaust Manifold and Riser Kit (4 inch) 1983-2002) on my 2000 stingray 190lx. The starboard side cooling water hose from the thermostat housing to the starboard side exhaust manifold is in question. Number one, the instructions said not to modify in length by cutting, but no matter how I adjusted the 90/elbow, it would kink my hose at the BOTTOM of the exhaust manifold water inlet because it was a bit too long. Now I also have brass plugs on the top front side of each riser and I’m wondering if that’s where I should be running my cooling water hose/s to either port/starboard side or both. Also, Im noticing a decent temp difference between the port and starboard side on risers (starboard being warmer). I modified hose length and rerouted it to ensure no kinks whatsoever. Has anyone else ran into this be chance? Thanks in advance!
