Christpher7
- Joined
- Feb 11, 2019
- 2
I have a 2000 Mercury EFI that has no power under load most of the time. On a couple of occasions feathering the throttle it will get a on plane and run. Once you let off it will start messing up again. Most all of the time it seems the RPM is limited to around 2000 while under load. Engine idles and revs great on muffs. New plugs installed. Fuel pressure 36psi at idle and checked while running under load having problem. Any help would be appreciated.. Thanks
