2000 Moomba movius wake help !!!
sebasendallas
Hi guys i just get a 2000 movius and im going to the lake with my wakeboard friend and my lest side off the wake is smooder than the other and i dont know why , other thing is even with the fat sac full i dont see a big dif with my old i/o
and for last how the speed control works ??? thanks
86 century
Ensign
Re: 2000 Moomba movius wake help !!!
Try to add some waight to the front end of the boat.
For some reason the supra/moomba hulls like to have there waight about 60% in the rear 40%in the front.
86 century
Ensign
Dave.Mishchenko
You'll want to balance the weight in your boat around to balance out the wake. My boat is 3600 pounds empty and moving around my kids (70 pounds) can have an impact an the wake. You'll also want to experiment with balancing the weight front and back as that can also shape the wake.
Is it the direct drive that you have? I beleive the hull is primarily for skiing so you might have to add a lot more weight to get a good wake from it.
sebasendallas
yes is a direct drive . thanks ill try with more weight
pocket aces
Try a fat sac on each side of the motor. Let us know how it works out for you.
