Rotorpilot1969
Thread starter- Joined
- Sep 8, 2012
- 35
I bought this boat a few months ago, knowing the bravo 3 needed replacing.... Boat did run but when I got her home it all got bad and then worse...... I then discovered a leaky fuel tank and did my research and was convinced the tank had to be removed, so I cut the aft cabin flooring out and then the wrecker came to remove the engine. Once engine was removed I noticed the pin hole in the tank that was repairable without removing the tank.... Great relief I thought! So the engine is out and I'm cheap in the boat, so I decided to put a ATK reman 350efi back in her just as a reselling point. Not knowing the transom assembly was bad at this time, I order the long block... Now I order a new transom assembly as the old one was brittle and broken ( salt water abused ) from lazy previous owner that let this boat rot in the wet slip for lord only knows how long, the outdrive had already been removed when I purchased boat but was given to me. The lower unit was literally eaten off!!
Now for the reason I've posted here in hopes to hearing opinions on the lower soft spot in the transom.... I snapped two inner plates before I figured out the bottom right corner of the transom was weak causing the plate to snap.. I tried a over the counter cheap putty repair job and cracked my third plate. I could torque all the bolts down to spec until the last twist and then the one crack in plate would happen.... In all honesty I knew better to try and putty as this is a nice boat and will be a very nice boat once it's all completed, as in new everything! So I started cutting away at the rot and have come to hard wood just above the second set of bolt holes from the bottom and about 6 inches across from the bottom over on both sides. It would seem to me the bilge had water in it and rotted out the bottom part of the transom. I have ordered some cpes and layup laminate and a void free piece of mdo to repair spot with. I have also notched out or allowed for over lay. My question and concern is will this be strong enough to absorb all the engine and prop torque? I'm afraid hammering down on the throttle may cause my new wood and epoxy to brake or hitting a wake could do the same... The boat is now a lake boat but at some point may return to the seas? I truly don't want to have to cut out the whole back of the transom...... What are your thoughts? I have pictures of what I've cut away, but don't think I can post because I'm new
Best regards, Al
Best regards, Al
