jluchuk
Thread starter- Joined
- May 20, 2008
- 43
I have a 2000 Larson Cabrio 290 with twin Volvo 5.0 GL PEFS 220 HP with Duo Prop out drives. The throttle, shift, and trim controls on the dual control top mount unit. They are the standard type unit with trim buttons in the port handle. When I put the boat in the water this year, when I went to start the port engine the handle fell off. I was able to get it on and then the neutral button stuck. Oiled and played with it and it seemed to work. This weekend after fixing my cooling problem went for a ride and had an engine quit. When I went to start the port engine again the neutral switch was stuck and all I had was throttle. This time I had to take the control head completely apart. Found the shift levers were hitting the trim switch wires. Could not get it to seat right - finally got it to the point of working enough to get the boat home. Next day I took the thing apart totally and found the wires must have moved. After fixing this problem and playing with the shift adjustment for hours, I got the thing to work. However it seems hard to move in and out of gear - it is harder then the starboard control. I have read that this type of control is prone to problems with the neutral button sticking and causing problems. I am also worried that this problem with happen again because I had no definitive fix. Several questions: Is there some type of friction adjustment on these controls? Does anyone make a dual lever (separate shift and throttle controls for 2 engines) that would would in the same physical space? ( I can always put the trim on separate switches.) Any ideas or help would be appreciated.
Jerry
Jerry
