2000 VP DP-SM U-Joints
CascoBay
I need to replace the u-joints on a 2000 VP DP-SM drive and I am aware that Volvo says you cannot replace just the u-joints- the entire shaft needs to be replaced.
I have searched and cannot locate any solid conclusions on this.
Is it possible to replace just the u-joints?
Thanks
CascoBay
Re: 2000 VP DP-SM U-Joints
Don,
Thanks as always!
CascoBay
Wow- I just got sticker shock on these u-joints, $75 a pop!!!
Volvo #3860232
Sierra #18-6406
Don S
Want to price the complete assembly???? Then you will get sticker shock.
CascoBay
Good point!
I know that you always recommend using OEM parts and I can certainly respect that, but I wonder if there is an alternative such as a Spicer # or something else that may be more common to the parts world.
CascoBay
Thanks again for your help.
I installed the Neapco 1-0005 and they fit perfectly.
I am afraid that I may have replaced them for no reason. The originals moved smoothly with no sign of problems. I had gotten some water in through a Sierra made bellows kit 2 years ago and replaced the gimbal this past year but not the joints.
I noticed at full turn the drive made a bit of noise (humming) that I assumed was the u-joints yelling at me, but I guess it was just "normal".
The Neapco's have a zerk fitting in the end cap and I plan to remove that after I grease them and install a plug as I am not sure on the clearance within the bellows.
