freetime99
Thread starter- Joined
- Sep 11, 2007
- 129
I'm looking at two used 19' boats , one of them has a s 2 stroke,90degr Yamaha 115. The engine looks clean and reportedly has about 300 hrs. on it. From those familiar with this engine, I'd like to know :
1. this engine have a good history, reliable ?
2. does this engine have two 2 throat carbs ?
3. I've spun the prop while it's sitting in neutral and there is a "clicking" sound
coming the prop shaft or gear housing - is that normal ?
4. what should cyl. compression range be in ? ( I'll check before buying )
5. there is an oil tank under the cowling as well as in the boat - why ?
6. the head gaskets dont have factory paint on them, is it reasonable to
believe that the heads have been taken off ?
thanks
thanks
