Re: 2001 15hp 4-stroke Evinrude --- Inaccessible Carburetor Bolt
2001 Evinrude 15hp 4-stroke:
Success!
First: I found 3 bolts that fit the threaded holes in the flywheel. The bolts are 5/16" diameter shank and labelled "fine thread", which i take to mean 5/16 and 24 threads per inch, because 18 threads per inch didn't work. Alas, when i got home, i found that the bolts were of different length. I made a pencil mark at the required depth on the SHORTEST bolt, then measured and marked the other two bolts to match. Then I wrapped tape around the mark on each bolt. Here is a picture:
I threaded each bolt into the flywheel until the tape bottomed:
Once seated, I turned the flywheel puller's center bolt a 1/4 turn, then tapped on it with a hammer. repeated 3 times and the flywheel easily popped off.
Second: Once the flywheel was off, I STILL could not properly loosen/tighten the nut which fastens the carburetor to the intake, without damaging the throttle assembly. The SOLUTION was this:
To access the inner nut, fastening the carburetor to the intake, remove the flywheel AND open the throttle assembly on the carburetor to the UP position!@
A very sincere thank you to everyone on these forums - and especially those responding to this thread.
Full credit goes to those people, whose tips I have read elsewhere on these forums, and copied here.
I will post a new thread, summarizing my experience with this motor, later this week.
Barkley Sound
