dieselfumes
Thread starter- Joined
- Jun 27, 2012
- 9
hello all. I have a 2001 20hp 4 stroke kicker motor that wont idle smoothly. it will idle but it is rough and some times it will pop and then stall. however It will start right back up and run for a while. also, when giving it some throttle it hesitates a little. then after running at a higher speed it will sputter after letting off the throttle. not sure if it matters but the squeeze ball on the fuel line has fuel in it but it doesn't seem to stay hard. ( not sure if it suppose to or not ) I have had issues with dirt getting into the carb in the past and clogging the carb needle. so I have taken it apart twice since I have owned it and cleaned and both times I have put a brand new carb kit in. float and all. each time I have measured the float to make sure its correct. I also did buy a repair manual and have adjusted the linkages and rpms to factory specs. gone over it many times to make sure they are correct. I also removed the tank and completely cleaned it. in addition after repeatedly having dirt in the fuel I have installed 2 fuel filters. one before the fuel pump and one after. the only thing that I can think of is the boat is a 21' with the kicker motor fuel tank located towards the front of the boat. to me it seems a long way for the pump to draw fuel. The engine did run rough before I installed the filters. in addition. i put the right sized filters and also made sure to install the clears ones so I can see if there is enough fuel and to see if there is any partials in there. so far everything is good. anyways , sorry to ramble on but I wanted to list everything I have done. its frustrating because my sons friend has the same motor and it run like a champ. thanks for any help. one last thing. I do have a pretty good mechanical back ground and I also have a complete shop to work on things............
