73makocenter
Thread starter- Joined
- Dec 13, 2009
- 12
I have a 2001 225 2 stroke Yamaha outboard. Back in 2011 the overheat alarm started sounding, replaced thermostats problem solved. Now,2013 alarm sounding off again, this time replaced water pump complete change. Went out first time since, alarm sounded off about 20 minutes into trip. Shut down then idled back a bit went off a short while later then back on while still at idle shut off. And several times after same problem. Water pump is discharging fine any ideas? Thank you for any help you may offer. 73 Makocenter
