Re: 2001 25 mercury stalling
I am having the very same sequence of problems. I have rebuilt the carb/fuel pump, bought new gas tank with new gas/additives, replaced fuel filter) and still stalling. From what I have read from other posts here my next step should be to check (and replace) anything leaking air in the fuel line from the tank to the carb (fuel line, bulb, fittings, etc.). I have bought a new 5' length of rubber fuel line and I plan to bypass the entire fuel supply line from the tank to the carb with the new line and see if I can start ruling things out. Does anyone see any problem with doing this? I guess I will have to find a way to prime the line somehow.
How did you all make out? (I know this is an old post that I am replying to and you may not be tuned in).
I will let you know how I make out.
Any other advise / suggestions from anyone is much appreciated.
