2001 5.7 L EFI.
team shadow
Not trying to steal this but I am having similar issue so maybe this will be the same problem.
I am having the same issue with a 2001 5.7 L EFI. Yesterday it was tough to start, but ran for 5 minutes ok, then then I turned it off and then another tough start and then it ran for about a minute then shut down. I have replaced the coil and coil wire to the cap and the distributor cap, rotor and the sensor inside. I can hear the fuel pump kick on but still no spark.
In you previous thread you indicated that this was a salt water engine which sat for over a year and you took it on as a project. Also you had it out and water was spraying everywhere. Did you replace the engine with a new one? Have you run through the TB5 troubleshooting sequence yet?
team shadow
Re: 1997 5.7L Merc EFI turns over but no spark. HELP!
When I replaced sensor in distributor there was 3 wires, red white, green white and black, the original only had 2 wires, Merc instructions said it was an accessory wire, so I was thinking something for an electronic gauge or something. Ended up it was a ground and that was all that was needed. So my original problem was the sensor and hooking up the ground completed the repair.
Re: 2001 5.7 L EFI.
Ayuh,.... 'n now yer Not stealin' that thread, But, have a thread of yer Own,....
Good luck,...
Fun Times
Sounds like you have her running good, Thanks for the update, Happy boating.:)
