Re: 2001 evinrude 200 hp ficht
I bought from same guy and had problems at first. You must download driver for cable to work , it may take a couple times of installing and removing it, it comes as a zip so you have to extract it. Then you have to designate a comm port on you pc, then you have to change the comm port on EV DIAGNOSTICS to match the port on your pc and then you are set , and make sure you follow his install instructions and how to register it. Its a bit of a pita and you are gonna have to know how to get into your pc to make sure all is well but after the hassle its all good.....good luck
dave
