My engine will start and run fine, the first time out motor ran for 20 minutes or so the just cut out. Turn key all three engine lights came on and would not start. After that it started up at dock and ran fine, but when turned off after only a few seconds or minutes ill get the three lights once more. It some times wont start again till next day and always on the first try. Ive done some reading on the EMMs and thought this might be the problem. I have good water flow thru computer and to fuel pump. This boat sat for two years and wasn't used much before that. Could bad gas or stuck thermostat be the issue?
