2001 Johnson 15hp 2 stroke specs/advice
mpsyamaha
Just realized I should have posted this in the nonrepair section, If a MOD wants to move it, go right ahead! thanks!
Just picked up this nice little motor, its a 15hp 2 stroke electric or pull start 15" shaft with very low freshwater hours. When i was a kid I had great experience with a late 80s 15hp that is essentially the same motor as best I can tell, so I was excited to come across this gem. In south FL a clean freshwater motor is very rare!
Information is not that easy to find about this model. Most anything I can find is for much older ones. Also, the wot rpm spec seems to vary from place to place. Basically, I just want to know more information about this engine.... things like the specs (weight, wot rpm, etc), and any other experience with this motor. Any info/experience is appreciated!
Im hoping to find a 14 ft jon boat or maybe a gheenoe to put it on. It came with a 9x11 prop, which seems reasonable for a planing application. I already have a saltwater boat, but really want a jon boat to set up for bass fishing :D
Sandor27
Re: 2001 Johnson 15hp 2 stroke specs/advice
My 2000 Johnson manual states the following specs for the 15:
Full Throttle Operating Range 5000-6000 RPM
Power rated at 5500 RPM
Idle RPM in gear 700+/-25
Weight R 72#, RL 77#, TE 75#, TEL 80#, EL 80#
Disp 15.6 cu in
Bore 2.375"
Stroke 1.760"
Gear Ratio 12:29 (0.414)
Gearcase capacity 9 fl oz
Fuel 50:1 mix
