2001 johnson 2 stroke fuel pump, diagram of inside with diaphragm and springs
hall832
2001 johnson 2 stroke fuel pump, i need a true diagram to see how it is assembled. i have in pieces. any help a diagram of inside with diaphragm and spring IMAG0473.jpg
Chris1956
Honorary Supreme Mariner
Re: 2001 johnson 2 stroke fuel pump, diagram of inside with diaphragm and springs
Gee, that is a real simple pump. It should have a diaghram and a couple of check valves. Is that your vapor pump, or a replacement for the OMS pump?
Watermann
It looks pretty much like all the rest of the OMC OB pumps. Watch close when you take it apart so you don't miss something. Mine was pretty easy to repair.
Rebuilding the OMC Fuel Pump
hall832
Thank you very much Watermann. that link had the picture i was looking for. it is very simple. it was missing the large spring and plate.
