JoshKeller84
- Joined
- Jul 2, 2010
- 220
hi guys, have a 2001 3 cylinder 35 hp johnson. oil mixer removed, fuel line run directly from second fuel pump to fuel filter to carbs. The past two times out, ive noticed that I lose fuel after running a mile or two. motor bogs and then dies. However, it picks up back and continues running for another mile or two if you pump the primer bulb - which leads me to believe its a fuel pump issue. my question is how do i determine which of the two pumps is the problem one? i've noticed my inline fuel line filter stays full, even flows a small amount of fuel to flow through the filter. I also see on the parts diagram, there are two different pumps, but only one rebuild kit - does this mean the internals are the same on both pumps? any suggestions? thanks guys!
