I have a 2001 Johnson 115hp outboard. It turns over great but does not start.
The rectifier and power packs have been replaced. Before I put any more
into this, I'd like to know if anyone has had this problem or what I should
look for. I think it is a simple electrical problem. No spark at the plugs
with a spark plug checker. My next step is the coils. they look worn as did
the rectifier and the power packs. hoping the coils are what is causing this.
The repairs I did had to be done anyway, but, did not solve the problem.
Any Ideas? I ordered a manual but have not received it yet. I have the key and
lanyard. Yes, key is in ignition. Any other thing that acts like the kill switch
I should look for? What is the most common things I should check? I know it will start if i can get spark to the plugs. Can anyone also tell me where to check all the grounds? Thanks.
