2001 Larson 190 LXI
I have a 2001 Larson 190 LXI 4.3 volvo-penta motor and outdrive. I removed the battery to charge it then reinstalled it, everything works good but the digital display (which worked fine before removeing the bat.) the display does not show up at all. Can anyone tell me why and how I can fix it. I do not have a repair manual only the operators manual.
dcg9381
Re: 2001 Larson 190 LXI
That's going to be a tough one.. The first place I would check is determine what the ignition-on power source is, make sure the display has power.
rndn
Check fuses, curcuit breakers, and maybe there is an additional wire to attach to the battery that you did not re-connect.
