rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
Hi All again,
Got some numbers, so I thought I'd update for some addtl input.
Someone told me to check vRef 5volts at several sensors, as only TPS, IAC, MAP, and Coolant Temp signal the ECU for fuel trim....So today, I probed each sensor wires, and found 5.19v at each sensor, EXCEPT the IAC. On that one there were 4 wires. 2 were .9v , the other 2 were 10v.
Question 1) Is this 5v theory correct? and are those values for the IAC 4 wires ok?
Question 2) Can the "sensing" wire on these sensors be measured for proper state at idle? Meaning the normal sensor state must present a voltage on the sense
wire for that should be a particular value, or range for that condition. Is it possible to get a ballpark base reading on these lines with a voltmeter?
I located a couple grounds, and they will be cleaned up for sure. But had solid continuity from Batt ground, to lots of areas on the block-So I'm lead to believe grounds seem ok.
Then per Alldodge, We jumped into Base Timing, and put a LED into E/F to inspect for codes...It blew the first LED, another one started to flash, then got hot and quit. My friend had a pack of LED's but unknown type. Maybe those were not "Resistor" type and blew each time. I guess we will have to locate some new ones and ensure they are resistor type.
Question 3) Lastely, we just had "key-on" when doing the jumpers for codes? Is it ok and preffered to be engine running?-dont want to blow anything.
Still pending an actual Fuel pressure test.
Thanks for all the help already-appreciated.
