2001 Merc. 175 EFI won't start
Jayhat777
Motor runs great right off the trailer but after shutting it down for a short time it won't crank back immediately, taking up to 30 minutes to crank again then the cycle repeats itself.
Faztbullet
Pull cowl and check spark when it does this. Either stator failing or high pressure pump/ECU problem
Jayhat777
Haven't had a chance to run it yet but I habe a little more detail to give.
After running it and shutting it down for a bit it will fire back up but kills when I try to throttle it.
