well, I'm not sure what I need to adjust. I opened up the motor with the intent of adjusting the idle screw. But I noticed a few things that made me question if this was the right approach.
With the throttle in the idle position, the rubber stop (blue arrow) is about 3/16" from contacting the stop pad (red arrow). When I rotate the screw (green arrow) up, the rubber stop moves back and makes contact with the stop pad and the idle goes down to around 900rpm. (current idle is 1500rpm)
Then I moved the throttle forward and brought it back to idle. Same thing, the rubber stop is 3/16" away from the stop pad.
I checked the cable lines and everything is free to move with no tight turns or kinks.
At first I thought I could adjust the throttle cable, but after doing some searching around here on iBoats I don't this is the right thing.
thanks for any help,
-john
-john
