2001 mercruiser mcm 5.0 will not start
clayton28333
Hello Everyone I am new here I have a 2001 mercruiser mcm 5.0 will not start engine cranks ok but does not start. Does not have fire to plugs are injector pulse battery seems to be ok. I have check kill switch. thanks for any help Clayton
Howdy, could use a bit more info, like carb, EFI, MPI
Is this a new to you boat?
If not new, how did it do last season?
Just need some onfo as to how it was doing previously and what might have caused this
Have a engine serial number?
clayton28333
Sorry EFI engine serial number 0M012165 Took out of storage and it and run for 30-45sec then turned off i can play around with it and it will start but cuts back off did fine last time it was out
Thanks for the serial number
Its TBI so that reduces so of the things to look for
It has EST ignition,so look for 12V on the coil when ifnition is turned ON and not cranking?
When cranking the motor, does the tachometer show any kind of reading and looking for around 300 rpm?
If the above to are met, then check the distributor as shown
