frozenokie
Thread starter- Joined
- Feb 4, 2008
- 309
I can't figure out what's wrong. I bought this craft to rebuild and sell. Electronically, everything worked until I completely rebuilt the lower/upper end of the motor. I have done a number of these so I know that the wiring is hooked up correctly and the motor did run before rebuild.
During first start-up it ran great. All hooked up with water for cooling. I ran it for no more than 5 minutes and I hit the start/stop button to stop the motor which it did. I then tried a restart - nothing at all, no beep, no signal to gauges, NOTHING:facepalm: So I started investigating...
I noticed the rectifier was burning hot to the touch! I also tested it with my meter and it tested bad. Never had it get hot before rebuild. However, I did NOT replace the stator and connector wiring during rebuild. So I replaced both the rectifier and the computer controller since it also was burning hot
But still had no luck. I tested the start/stop switch - tested OK. Wiring looks clean and not burned. Fuses are good. I can jump solenoid to start so that electrically is good also.
I feel I should have replaced the stator now - hind sight 20/20
But believed it would work fine since it did before. But I cannot figure out how and where to check the stator to see if it's bad.
Can someone tell me how to check it or tell me if there is something in diagnosing that I need to check out???
