Dave-R
Thread starter- Joined
- Mar 18, 2008
- 441
I just bought a used boat with a volvo 4.3 . It is a carb engine with the delco distributor. The engine starts and runs fine in neutral. As soon as you you shift into forward or reverse, the engine dies. Not from the outdrive being frozen, but like the old mercruiser interrupt switches that momentarily killed the engine when shifting. The ignition switch was removed and jumpered to start because his father had the key in Idaho. I rotated the prop in neutral, forward , and in reverse by hand and the drive works as it should and there is no binding. I'm wondering if the neutral start switch could be out of adjustment. They had a new engine installed by a Marine dealer last year, but did not put the boat on the water. I pick it up Monday so until then I have time to think about what to check first. Maybe with the ignition switch jerry rigged, it has caused a problem somewhere downstream. Any ideas where to start looking? Thanks Dave-R
