2001 volvo penta 5.7gs pefs surges
hubcap
When accelerating engine at about 2500-3000 rpm engine will sometimes (usually when hitting pretty hard)rapidly increase rpms. have to pull back on throttle to slow it down. I have heard this is caused by inproper trim?
Input appreciated.
Re: 2001 volvo penta 5.7gs pefs surges
Ayuh,... Entirely Possible,....
Tell Us how you go about operating the trim on your boat, at various throttle setting,..??
hubcap
/engine is pushing a 01 fourwinns 210 horizon.
Out of the hole drive is down all the way according to the gauge. I hit it with throttle as rpm go up raise to middle of gauge and trim it out for optimum speed and rpm. am I not getting it on plane soon enough?
could it be caused by a throttle linkage problem?
Don S
Go out and play with the trim and try different things. That's how you learn. Without being with you, it's impossible to say if you are operating it properly.
I would also suggest you forget the gauge. Put the drive down till you hear the trim pump sound funny. Then go. start trimming up and see what happens.
