2001 Yamaha 225 OX66 idles higher on the hose than in the water..Normal?
sunbird 18
2001 Yamaha 225 (SX225TXRZ). Long story short, it idles at about 650 in neutral in the water, and idles at about 900-1000 out of the water on the hose. Is this normal? If not what could cause it?
k4ubr
Re: 2001 Yamaha 225 OX66 idles higher on the hose than in the water..Normal?
that is normal for all outboards do that there is no back pressure (water)
rodbolt
actually on an EFI motor its not normal.
the ECU will control the idle speed based on inputs from the 02,sensor,crank position sensor,Throttle position sensor and the coolent temp sensor.
if the ECU sees a cold engine it will hold the idle high.
your engine should start at about 1200 RPM then as it warms up it should drop to about 700 RPM. however with no back pressure and especially if the O2 sensor needs maint it will idle funny.
your idle speed in nuetral is about 730 RPM and in gear trolling about 625 RPM.
k4ubr
if this where a 4 stroke that would be. this 2 stroke will idle 900-1000 out of the water. normal
