pontoon chief
Thread starter- Joined
- Aug 9, 2004
- 116
Have a 2001 yamaha 2 stroke that sat in a dealership for three years and than was sold to the dealership I work at<br />Motor starts but runs rough.When it got to the shop it was missing the sparkplug ends and a few other items.<br />When I start the motor I can pull the plug wire off of the middle cylinder and it does not effect the engine at all.I can hear the spark snapping to the plug when I put the plug end back close but it seems to have good spark,the bottom cylinder is the same.The only cylinder that seems to be firing correctly is the top one.<br />I took botton two carbs off and checked,both carbs are clean and free of any dirt etc.<br />It almost seems as if the motor is starting in the RPM reduction mode.Oil tank is full<br />Compression is good all cylinders and just switched the plugs.<br />When running I can put my hand in front of the two bottom carbs and it is pulling gas into the cylinders.<br />Any suggestions...........
