2001 Yamaha C40 TLRZ tachometer
silverfarm
Hello,
Recently bought my first boat: a 2002 Lund Rebel 1650v with a 2001 Yamaha C40hp TLRZ.
Console with no gauges.
Can anyone recommend a tach for this setup?
Perhaps a better (dumb) question from this noob is....Why a tach? I mean how to use the information it gives me?
To monitor wot and idle rpms?
Thanks for your replies.
99yam40
Re: 2001 Yamaha C40 TLRZ tachometer
will tell if you are propped correctly, where to run the motor to get the best mileage, troubleshooting and finding problems with not performing like it use to, etc.
cwhitlock
Hey Silverfarm i have a 1998 C40 and just finished putting a gauge set in my boat. I bought a teleflex set from basspro and put in the boat including a tach, speedo, fuel, and volt meter.
silverfarm
thanks for the info CW,
BPS does not list a yamaha wiring set for those gauges.
this is all new to me.
i would want only tach.
where does wiring connect to?
thanks
99yam40
My C40TLRX has a 4 wire connector coming out of the remote control.
I hooked up the tach to the
Yellow for key on power
Black for ground
Green for signal
Red is hot all the time so I did not tie anything to it.
make sure the tach is set to 6 pulse.
