69 Alumacraft
Thread starter- Joined
- Nov 15, 2009
- 173
So the gear oil was fine at the beginning of last season. I filled it and used new washers. Now it is milky. There is no evidence of a leak, I removed the prop and checked for fishing line. The water pump is about 5 years old but still pumps fine. I am planning to replace the pump, housing and seals that go with the water pump and then give her a try and check the gear oil again after. My question: WHat is the likelyhood that my leak has something to do with the water pump? I am comfortable doing the pump but not going to pull apart the LU and do the internal seals. Also how hard is it to replace the shift shaft seal on these models?
