Suachris
Thread starter- Joined
- Oct 13, 2015
- 2
Hi All,
I have a 2006 Gemini Status 5.05m RIB with a 2002 115hp 2 stroke Yamaha outboard. The motor has done less than 100 hours.
Since buying the boat second hand, cold starting's been a problem. Once running, it ran fine although smoking a lot and consuming a lot of oil.
I read heaps of posts but none of the potential solutions worked for me.
I eventually sorted it out and wanted to share what the issues were for me in case it helps others.
In staring at the engine and pulling here and pushing there, I traced a linkage from the bottom of the carburettor on the port side and found it wasn't attached to anything. I eventually worked out that it was the control rod controlling the autolube valve. The plastic end perished and split, allowing the rod to fall out.
Yamaha fortunately engineered the pump to fail open to prevent engine damage. This does however mean that at idle, the engine was getting the same amount of oil that it would get at WOT.
Replacing the clip saw a huge improvement in cold starting and oil consumption, but only when using the manual choke lever. The electric choke would only work sporadically.
Working out why the choke wasn't working became the next challenge. Pushing the key in only activated the choke at times. The wiring checked out and there didn't appear to be any other obvious issues.
As I only had one key, I wanted a duplicate key and had to pull the key from the rubber grip to get the number for the replacement key. In this process, it became clear that the key had corroded through at the eye for the key ring. This resulted in the key sliding back into the rubber grip, giving the impression that it was moving into the lock and activating the choke.
A new key solved that issue.
Starting the engine now was a case of lowering it; I found that priming it if the engine isn't lowered makes it almost impossible to start; priming, fast idle lever up, pushing in the key to activate the choke and spinning it for 5 to 10 seconds and it would start every time.
That lasted for most of last season, until the electric choke stopped working again. This time it was a small rubber grommet at the bottom of the choke solenoid mounting that had perished and split. As the choke rod runs through the metal housing, the absence of the grommet made it bind and the electric choke wouldn't operate. A new grommet and some lubricant sorted that out.
Now it is back to lower, prime, fast idle up, choke, spin and run.
I hope this information may help others with similar problems.
