ot556519 no power to key at all , on motor there is a fuse holder with 4 fuses , the 20 amp fuse that is for main power relay,remote control harness and power trim has no power to either side of fuse with key on, nor does another 20 amp fuse for ignition coils.the other 2 fuses get power. battery's are charged, all connections cleaned on battery and on motor positive and negative. it did start 2 times but dies after soon after , once about 2 minutes , 2nd time 10 seconds like a kill switch was pulled. any ideas, I changed ignition switch. the first time it started was with old switch 2nd time with new switch
