2002 200 HP Ficht "Oil Fault"
KeeperSeaker
Trying to figure out which part I need to check or change. I recently had codes 38 and 39. Few weeks ago I put in a used oil injector along with the oil pressure switch which was included. I changed it because one of the ports that hold the retaining clip for oil hose broke and I was also getting intermittent oil fault light while monitoring with laptop. I crimped the oil return hose right before oil pressure regulator to get any air out. Motor smoked when accelerated. Did this 3 times. While monitoring with laptop oil fault was on again and stayed on but I noticed that it changed to oil ok when I crimped the return hose. Now I am wondering if I got a bad injector,oil pressure switch or if it is something else I missed?
seahorse5
Re: 2002 200 HP Ficht "Oil Fault"
Weak oil pump, very common, or bad pressure regulator, restricted oil screen in return line
Anchor Management 1
I just call BRP about the same thing and it is a well knowen fault with the ECU Just sent it in to have it repaired by an aftermarket company.
KeeperSeaker
I was thinking oil pressure switch or pressure regulator. Any way to test any of these parts
