2002 25 HP No Fuel
baitbucket1
25 HP Mercury appears to be not getting fuel. Fuel filter is full but not getting to the carb. Any suggestions.:confused:
baitbucket1
Re: 2002 25 HP No Fuel
Carb was cleaned and I was told :confused:it could be the trigger switch, stator or power pack. It will crank when you prime it but after the fuel burns off it shuts down, which one of the above could it be,.
Don S
None of them, those parts are for the ignition, and obviously you have ignition or it wouldn't start. You have a fuel problem.
Prime it again, and start it. Then keep pumping the primer bulb after you start it and see if it will keep running.
If it does, you may have a faulty fuel pump.
baitbucket1
Sounds like the inlet needle is stuck
It was replaced. Motor is doing fine now. Had one more problem but that is also solved. Bad gas tank, it was bought new and turned out to be a bad one. Thanks for the advise.
