2002 - 3.0 Mercruiser Alpha 1 slugish throttle at times
Moose_25_2500
Just replaced drive belt thanks to everyone here. Super simple and now have one in the glove box just in case...thanks again
So I have a 2002 bayliner classic with a 2002 3.0 mercruiser with a alpha one. She starts every time and runs good most of the time on the water but about twice on the last couple of times out it would not go more than 10 mph for a about 5 or 10 minutes. (2 of the 4 times had a skier on the line) not running hot and has fresh gas. Also the last time I went out she started right up and when I gave it gas in neutral it sputtered a little bit in-lieu of reving but did not cut out and was fine when I put it into gear.
where should I start first? filters? thanks for any help you can give
Re: 2002 - 3.0 Mercruiser Alpha 1 slugish throttle at times
Ayuh,.... Welcome Aboard,... It sounds like a fuel delivery issue, so, Ya, start at the filters,...
achris
More fish than mountain goat
I'd also plumb for new spark plugs....
Moose_25_2500
I ordered the paper filter for the fuel pump. Mercruiser part #803897Q1....where do I find the part number for the filter in the carburetor? I don't see a filter in the mercury parts catalog? is it the strainer? my engine serial number is 0M336627.
thanks again for your help
dswi
I am told by the local (3 hours away) mercruiser dealer that the filter on the fuel line going into the carb is cleanable. I know mine was. Super easy to change/clean (preferably change).
NHGuy
Yes, you can remove it and clear it out with carb cleaner. Or new are cheap too. To look up the part # put your motor info in here
https://webapps.brunswick.com/literature/literatureSearch.do
and find the appropriate page view. Or just go to the top of the Iboats page and go by model or part #.
Moose_25_2500
The Mercury site is where I went to find the filter in the carb but, there is not a part labeled as a filter. See the attachment. Are you refering to the strainer listed as item 4 - part #53336Q?
  • Mercery 3.0 Carb Assembly.pdf
achris
The Mercury site is where I went to find the filter in the carb but, there is not a part labeled as a filter. See the attachment. Are you referring to the strainer listed as item 4 - part #53336Q?
That's the one...
Moose_25_2500
thanks for the help. What's the best place to order parts online for quality and quick delivery? Funny I tried to order the fuel filter on iboats to "pay it forward" and it was out of stock
Moose_25_2500
Crazy update. So I change the fuel filter under the fuel pump first and then take off the flame arrestor to take a look at the carb before I change the one in the fuel line and notice that one of the plastic tabs broke off from the cover and is laying inside the carb. See the attached pics...you have to blow up the pic to see it on the right side I feel pretty stupid for not removing the flame arrestor last week. so i use a pair of needle nose pliers to remove the piece of plastic but, still notice a few shavings of plastic laying in the carb. So was that my problem all along? and whats the best way to remove the shavings. I dont want to start it up in fear of doing any damage? thanks for your help.
Moose_25_2500
2002 Mercruiser 3.0 Alpha 1 ----S/N 0M336627
So I need to order a new flame arrestor 4 sure and my part is the one with the molded hose retainer #863200 but it seems to be a cheap piece of plactic since a large piece ended up in the carb. the parts catalog lists #805016A1 as a replacement as well but it has a seperate retainer that is no longer made. The 1st one is $115 and Mallory makes one thats $70 thats looks like it has a retainer that will work?
Mallory Flame Arrestor 9-31101
Save 22% Off.Mallory Flame Arrestor 9-31101
Sale Price: $70.19
Save: $19.80(22% Off $89.99)
Part # 9-31101
No Reviews | Write ReviewLow Price Guarantee
Sale Price: $70.19
Part # 9-31101
Ayuh,... Got a Picture of it,..??
Moose_25_2500
Here is the parts diagram & specs. last one was wrong
  • Fuel Pump and Carb.pdf
