dollar7499
Thread starter- Joined
- Jun 2, 2013
- 62
1998 block 5.7 Bravo 3 built to spec of # 4312025PS (the # Crownline gave me from the hull #)
The P.O. replaced a cracked 2003 engine with a 1984 long block and sold it to me. I yanked the 84 and installed a 1998 long block, 4 bbl marine intake, marine quadrajet, and the box of correct model parts I received with the boat. I finished installation and it fired up and purred the first try. Set base timing, and then after a good warmup decided to give it some RPMs... when I got to 3200 RPMs I saw clouds of steam coming out of the prop. I immediately shut it down and checked the oil - everything was good.
It has the 3 point drain raw water cooling with only water inputs on the manifolds, none on 6" extensions or elbows. Cleaned up bravoitis during rebuild and flow looks good, lots of water coming out below transom but not much coming out prop. My elbows were getting pretty warm though, is there a chance too low of flow through elbows was causing steam? I flow checked all exhaust components during rebuild, so where is this steam coming from?
It's in a 2003 Crownline 262 CR Thanks!
