Re: 2002 Bayliner 185 Tachometer not functioning
Does the needle move at all when you turn on or turn off the motor? Has the tach ever worked?
Check the connections on the back of the tach There needs to be a battery negative , a battery positive (from the ignition switch), and signal connection, in addition to the connections for the light.
