2002 Bayliner 2855 - MerCruiser 350 Mag Bravo 3 diagnostics package
Motosparkz
Hi Guys,
Hi guys, just found this little forum & it seems you have a wealth of knowledge here, so hoping someone can point us in a right direction. I'm an auto-electrician by trade, but not having worked on boats before as such. We are over in the UK & we have recently bought our first MerCruiser powered boat & we are experiencing issues with it. I have tried a few local mechanics but no-one has any diagnostics, so hoping you can help.
I have been through the ID pdf you guys have, but cant narrow down what we have exactly, ref engine dates. On the engine build plate it says: "350 Mag BRAVO, 864377-3, 884521, ??p5AAAv_0037_5.7_BRAVO_P_AB20531005" (question marks, I just cant read what is there) She is running the Bravo 3 outdrive.
Right, the problem, basically the previous owner had her 3 years, but hardly ever took her out as he was a bit scared of her, (our marina's dont half cram us together so lots of risk just getting in & out) The marina where we are is onto a small river, which has speed restrictions so it's a tad hard to test for more than a few hundred feet without upsetting someone.
When we went out on test, she appeared to have a misfire & the warning alarm came, running a continuous tone, running reduced power. The boatyard changed the fuel filter, we took her out again & all seemed well, got on the plane nice & quick & rev'd out to around 4800 rpm so thought that was sorted. we bought her, nibbled out of the marina, we then got a double beep alarm, she then went onto a continuous tone again & reduced power right down to the point we only just had idle with reduced cylinders, (not sure if the Guardian system is clever enough to shut down cylinders) We have replaced the plugs, oil & filters. The only thing non-standard is someone has put a pancake filter on, as opposed to the full flame arrestor but tbh, not having seen one before this may be just the std filter with the arrestor removed, although the cam breather just goes to near the filter, it's not attached??
Anyway, we then got her back in, fully drained the tank to get rid of old fuel, took the tank outlet out & noticed the one way ball valve was a bit rusty looking so replaced that. Took her out & all seemed well apart form when bimbling at around 6kn, every now & then she would still double beep, around every couple of minutes or so, but no effect on running, it seemed after running the engine blower fan, the beep went away, so we thought that was maybe an emission in the engine bay alarm.
This weekend we went through the lock & did around a 40 mile round trip, most of the time she behaved, but occasionally gives the double beep, & then by the end of the weekend we have been experiencing the single continuous tone, but this only appears above 3200rpm, stays on until the engine is brought back to a complete idle, & it then turns off, till next time we try to get above 3200rpm. Another thing she has done maybe 3 times now, is when dropping to idle, if you dont listen carefully, she sounds like she cuts out, but immediately catches again, sort of like the anti-stall is kicking in, then the IAC valve plays catchup & raises back to idle, she has never stalled though. Pretty much through the whole rev range she does sound sweet, apart from maybe 2600 to 3000rpm, but cant really decide if it's engine or cavitation as we get no shuddering, just something sounds off.
So, is any one that clever to point us in any direction, (knowing my day job I know exactly what you will say), so 2nd question, seeing as we cannot find anyone local with diagnostics, is there any system you guys can recommend for us. I seem to recall seeing a dash gauge which gives a read out but not sure ours is advanced enough on the management to have everything in place.
So, whats says you guys, any good ideas. Obviously in the day job I wouldn't like to add up how much money I have in diagnostics, but then again, if I'm going to buy something it has to do it's job, dont want some little obd reader from fleabay lol
Cheers in advance, & sorry for the essay. It does vary every time so sorry about the long winded descriptions :-(
Cheers, Shane
alldodge
Howdy
The thing with the 555 ECM is there are many things which can cause similar issues. Best way to fin out what is happening is to read the smartcraft gauge (if available) or have the engine scanned for codes. The list below shows all the possibilities. The one which gives most issue is the seawater pressure switch. This switch is located on the power steering cooler and has a 2 beep mode and a constant beep with power reduction.
Motosparkz
Now then AllDodge,
Cheers for that. Just one question, we dont have the Smartgauge so is this a do-able retrofit, i.e. does it read off the diag port, or do these require sensors adding. This is what I saw advertised so wonder if it's a cheaper way to get diag over here as like I say, we have tried all the local boatyards within a 50 mile radius, but as usual we are so back & beyond over here, either no beggar wants to help, or they dont have a clue, hence looking at getting something ourselves :)
So, can I ask, as I struggled before to find out, going off the numbers I posted, that definitely makes us a 555 ECM
Cheers for the reply mister, Shane
alldodge
I would know better if I knew the engine serial number, but being the boat is a 2002, I'm assuming it would be a 555 ECM. The ECM is the one on the right
If this is the case then there should be a 10 pin connector similar to this one on top the motor. This is a pic from an outboard, but connector is the same type
This connector can be connected to a smartcraft tachometer or speedometer and provide info of problems. It cannot provide all info
Other things which can provide the info is the Rinda scanner and Diacom software.
http://www.rinda.com/marine/marine.htm
As before, the one sensor which gives Merc's the most trouble is the seawater pressure sensor.
Motosparkz
Wayhay,
You sir, are a Guru :) We are heading back to the Marina next weekend so Ill double check. Pretty certain I have seen the 10 pin, (albeit with a waterproof blank covering it, I'm used to 2,3 or 16 pin in the day job lol), just sat loose towards the sterndrive in the V of the heads.
Question, have you had much joy cleaning the sensors, or is it worth popping a new one in. Might be worth this one clutch of a straw before I spend money on a gauge/diag.
Cheers mister, appreciate your help :)
alldodge
Cleaning has helped at times. The sensor needs a good ground, so it the mounting bolts are loose, this can cause some issue. The sensor is set at 1 Bar so not much pressure. Maybe call around and ask if the marina/boat places can scan for the 555 ECM. Many have just replaced them, but as before it could be something else. Also if you do just replace it make sure not to use anything on the threads other then what comes on it.
To connect a smartcraft gauge I should also mention it takes cables, connectors, loads and such items.
https://mercurymarine-gsdesign1.net...m_tachometer_and_speedometer_installation.pdf
Motosparkz
Cheers again,
Will take a look & see what we can see. Unfortunately we have tried the boatyards within a 50 mile radius, but no-one seems to have anything hence needing to go our own way. The wiring & install is no drama as it's my day job so not a biggie. One good point of doing the gauge I see is that you can run GPS, I'm presuming this will pick up speed over ground too as at present the 2 gauges we have inop are trim & speed so this might fettle those too :)
