scubasteve49228
Thread starter- Joined
- Sep 21, 2009
- 5
I have changed the primary pump and fuel line from tank. The motor runs great except for 5000,-6000 RPMs then after 2 minutes the RPMs drop and fluctuate intil I bring the throttle to idle then after a minute it runs fine. Then again it does the same thing. I also pulled the check valve in the tank and it is fine. Also it gets worse as I keep repeating the above. I then return to the dock, let it idle then the same thing happens again. Thanks for any help.
