2002 EFI Sluggish
ACAMACIAN
I have a 2002 Merc EFI 225hp motor which I recently purchased. I have been trying to get this set up with jack plate adjustments and took it ouy for a run today. It worked Ok at first then it sputtered getting out of the hole a couple times. I let it sit a little, while I fished a favorite spot but when I tried to go it bogged down and could not get the boat on plane. I had to limp back to the dock, 2hrs. Now I am running the champion plugs it calls for but a couple outings I ran the equivalent ngk plugs. Could I of done damage. I ran the champs last weekend and they worked fine then. I am taking it to my mechanic tommorrow but I am just wondering if anyone had any ideas as to what it could be. It felt like I was trying to pull up a 500lb water skier and not getting on plane.
ACAMACIAN
ACAMACIAN
Re: 2002 EFI Sluggish
The mechanic took a quick look and says the compression is good on all cylinders But found some aluminum on one of the plugs, it sounded like it was missing and rough. What damage could I have done. I never got to talk to the mechanic that worked on it as he was out on an emergency call, but what should I brace myself for!!
" THE ACAMACIAN "
