2002 evinrude 175 ficht bad cylinder/piston
fishmonster13
2002 evinrude 175 ficht #4 cylinder compression is at 35psi , cylinder is scored would assume the rings are shot as well, what would cause this? and are the cylinders nickasil and can they be honed?IMG953319.jpgIMG957097.jpgIMG959274.jpg
multimech
Re: 2002 evinrude 175 ficht bad cylinder/piston
Looks really dry and scored all the way around. Usually an overheat affects higher cylinders first. I think you should check into the oil system and make sure it working correctly. At least a new oil lift pump on the rebuild.
fishmonster13
thanks, multimech , thats what i figured just wanted to be sure
