2002 Honda 90 on Pontoon
tomtnwlkrs
Ok, finally finished putting a 2002 BF90A2 on the pontoon boat. The boat is rated for up to a 90hp so it worked well. After all the rigging and wiring I put the motor in a stock tank for the initial start to make sure it was going to start. I haven't done any work on the motor except change the fluids. Went to the lake yesterday and it was windy and cold but not too bad. After i let the engine warm up for about 5 to 10 I headed out for open water. Initially I could only get it up to about 4000 rpm at wot. After running about 20 minutes I would slow down and then open it up to wot. It would spin up to about 5400 for 10 seconds or so and then go back down to 4000. I played with the trim to see if it would help. Can anyone give me an idea as to what the issue could be on this motor?"
Thanks
AGENT 37
Re: 2002 Honda 90 on Pontoon
Maybe water in fuel or a fuel line leaking air in. Do you use a fuel/water separator?
