2002 johnson 150 very hard warm start. heat soak
4.0l sahara
Well this 2002 johnson 150 has always had a little warm start problem since new. It is a fairly low hour motor with great compression. The thing runs great and idles good when cold. If you shut it off and let it sit for more than 10 min forget it. It takes like 10 or more tries to get it going. It will start and barley idle and will not take any throttle. The primer or pumping the bulb doesn't help. I just did the carbs a second time. I did them last year. This time time I used oem kits and put new float bowls on. I replaced every gasket from the block out and checked the reeds. Still have the same warm start problem. So should I take a look at the ignition now? I also rebuilt the vapor separator with a new needle and seat. Also has a new oms pump and good flow from the gas tank. I'm so sick of this thing what should I look at next? Sorry for any spelling this is from my phone.
4.0l sahara
Re: 2002 johnson 150 very hard warm start. heat soak
I also replaced the primer bulb.
4.0l sahara
bump
Silvertip
Honorary Supreme Mariner
Have you tried using the fast idle lever during warm starts? Many folks don't even know they have one!
DC20
I have the same problem. I have started to use the fast idle lever as Silvertip mentioned. I am now experimenting with different techniques. This was also mentioned by Chris as he has the same motor.
4.0l sahara
Yes it wont even try to start in fast idle....
Chris1956
Is the shift assist switch stuck? I am starting to see that more and more on my '98 Johnny 150HPV6.
4.0l sahara
I'm going to bump this back up. I feel defeated by this dumb thing. I'm a mechanic and this thing just has me stumped. Last summer I did every thing in the first post and I ohmed out everything. Pulled the flywheel and checked the stator too. I ended up just throwing a optical sensor and power pack on it because I was just fed up and hoping for the best. I will say those too things seemed to help but it still isn't right. Anybody? This thing has done this from almost day one. When it was under warranty a couple places looked at it and couldn't fix it.
