2002 johnson oceanrunner controls wont work
florguy
Hello all: I have a 2002 johnson oceanrunner. I hadn't used it in 6 months as I was out of state working. When I came back, it ran rough. It kept cutting off, no doubt the gas was old. I thought if I burned off the bad gas, I could then put in good gas and it would again run smooth. Stupid me. Eventually, it was so bad, I managed to limp back to the dock.
The engine was completely dead. It wouldn't even try to start or kick over. the power trim didn't work, I had to manually loosen the screw to raise the tilt and trim. Now, the controls wont work, you get nothing. Is there a fuse somewhere?
I tried another battery directly to the outruner from the controls for trim in the outboard itself. Nothing as well. Is there a main fuse somewhere? The battery wasn't too dead, and I gave it a complete charge on my charger and it still wouldn't work anyway. Please help. thanks.
tashasdaddy
Re: 2002 johnson oceanrunner controls wont work
there is a fuse on the port side of the motor, 99% it is blown. it controls the starting circuit, and tnt.
florguy
Thanks. do you by any chance have a photo or link to url that depicts it so I can find it? Is it port facing forward? reachable by human hands?
tashasdaddy
usually port side, rear, near stater solenoid. will be red. also sounds like you have dirty contaminate carbs.
