2002 merc 200hp carb warning system?
andrewcoon
I have this outboard which is analog gauges and I think it would be bad bass to have a check engine light (tho hope its never on) to tell me if I have a problem.. it has the buzzer could I wire the light into the buzzer? So say it over heats the buzzer will go off and so will the light.. if this will work I want to know what kind of sensors it has that would make the buzzer go off thus sending a check engine light. Temp? Low oil? Low water pressure? Also since this is not EFI it does not have a fuel water separator with a sensor however I have one off of an old efi mariner that I want to install and hook to the light as well... I dont know why I think It would be cool. But I do.. thanks
Faztbullet
Re: 2002 merc 200hp carb warning system?
I had a 12 red LED on the dash of my Bullet as you couldnt hear the hot buzzer @70+mph and I didnt look all the time at water pressure gauge. On yours if tied to buzzer you will get: 1) solid light if hot 2) flashing light if oil related 3) flashing light at self test
wired247
andrewcoon
Sweet! Thanks guys, this has the buzzer in the motor does that warn the same things the one in the control box does?
wired247
Wire it into the control box.
