andrewcoon
Thread starter- Joined
- Aug 21, 2011
- 130
I have a 200 mercury carb it's a 2002 and I changed the impeller and when I first started it, it pisses perfect. BUT now when I take i took it out it only pees when Ithe warms up. And at idle my water pressure is 10 psi which is good. But even with that 10 psi it still is a light **** and sometimes doesn't **** but only mists okay when I Rev it a little the water pressure gauge goes up as it should but when I plane it out it goes up to normal but then goes right back down to 10-11 the thing is last trip out it pissed after 30 seconds and at wot had a pressure of like 20-25 psi.. now it takes until 140 degrees to pee. And has good idle water pressure but low wot pressure. Also does not get over 160 degrees. I'll get a video soon.. thanks for the help sorry this post may not make sense I'm typing this on my phone
